XChallenge quick reference thread.
Losttheplot
Hampshire,UK
Thought an information only thread for general bike parts might be useful for those of us that get through a few err...consumables:, and focus all the required answers in one simple thread??
Seeing as i have them in front of me:
Front wheel bearings are:
SKF explorer. 6004-2RSH/C3
Sprocket carrier/cush drive:
SKF explorer. 6005-2RSH/C3
I'll add rear wheel bearings and seals as soon as i pop them out.
I guess this could extend to oil filters, air filters, replacement gear levers to ect.
Oil Filters
K&N: KN151
HiFlo: HF151
Delo: #7
Champion: X305
Seeing as I have them in front of me:
Correct me if I am wrong, but my understanding is NOT to go for the C3 bearings ... C3 is for high temp high speed rotations and has additional clearances? Ergo not suitable for motorcycle wheels (unless you want them to wear out faster)
http://simplybearings.co.uk has them at about 4 quid a bearing for the SKFs and about £2.50 a bearing for the cheaper ones)
Another useful bearing part: Chain roller bearings ... you need 4 of them: SKF 6082RSH
Anyone have the wheel bearing seals handy?
Brake pads:
Front:
EBC FA209/2
LUCAS/TRW MCB 671
Ferodo FDB2006
SBS 674
Reae:
EBC FA213
Lucas/TRW MCB 672 LF
Ferodo FDB2005
SBS 675
Wheel bearings:
Front: 20X42X12
Rear: 25x47x12
Wheels seals size:
Front 25x42x7 2545TC
Rear 32x47x7 32428TC
Fork seals:
45x58x11
Brake lever:
Adjusted lever for Honda nx650 - L1B-MAN
Spark plugs:
NGK DR8EB
NGK DR8EIX
distance 0.6-0.7mm
Battery:
Varta LF -> Varta part# 508 901 015
Yuasa YTZ10S
Sprokets
Front BMW F650 Dakar
Rear Husqvarna TE - e.g Stealth Supersprox needet to exchange bolts to standard enduro one.
C3's are what BMW supply if you want bearings, i'd just taken the code off them.
:thumb for simply bearings.
Head bearings..
tapered roller bearings for steering:
code:320/28x
dimensions: 28x52x16mm
Just ordered: SKF 32028XQ as replacements.
code:320/28x
A good idea to keep a set handy ... I am on my 3rd set of headset bearings after the Sibirsky Extreme Project
PEGS:
According to Fastway F3 pegs description at TT USA site:
Fits BMW G450X and G650X
Also fits Honda CR 2-Strokes 1995-99, Gas Gas (All), RM125/250 2-Strokes 2003-2008, YZ-F/WR 250/400/426/450 1998-08 4-Stroke, YZ125/250 2-Strokes 1997-09, YZ85 2003-06 F3 Footpegs
code:320/28x
How about KOYO 320/28JRRS ?
Simply bearings sell them cheaper than the skf and they have a seal built in to them.
rear wheel bearings are also 6004.
afam make a steel rear sprocket for longer life.
Clutch Lever
Ignore the numpty on ADVrider who suggested a suzuki drz clutch lever fits. It doesn't!
I did manage to get a cheap replacement but don't have a part number, or even the bike it was from. If you call Swampy at Marsh Performance on 01752 844456 he should be able to sort you out. He had a 2nd hand one that he sold me but also had a new one in stock so should be able to order more. Make sure you ask for the plastic wave washers for it as well.
You need to drill the pivot hole out from 6 to 8mm. Once you have done this it fits perfectly and, with the wave washers, does not flap up and down like my original one was starting to do. Even the new lever was half the £28 bmw expect.
Tell Swampy that you got his number from Iain. It will help him work out what you need.
I fitted one on mine no problem :nenau
Unless you have a different perch on yours, or were supplied with a different lever?
On mine the original lever has a 30mm fulcrum measurement (from pivot to cable seat) while the drz lever that I ordered had a 26mm fulcrum. It might do as a get you home but not as a long term replacement. The effect of the shorter fulcrum measurement is a lighter lever action at the expense of a shorter cable pull. You could end up with the clutch plates not separating fully or, worse, the cable being under constant tension which will eventually fry your clutch
Fuel Filter
Puzzling me.
There is nothing anywhere on the internet, nothing on any online parts fiche. What the hell is it?
Looking at it, it has KL315 written on it.
Wheel Bearings and Seals
Just to clarify since it isnt totally clear how much of each you need:
Bearings Front: 2 x 20x42x12mm. SKF 60042RSH
Seals Front: 2 x 25x42x7mm R23
Bearings Rear: 2 x 20x42x12mm. SKF 60042RSH
Bearing Drive Hub: 1 x 25x47x12mm SKF 60052RSH
Seals Rear: 1 x 32x47x7mm R23 + 1 x 32x42x7mm R23
Note; The seals are very cheap and a 2 second job to change. If I were a wiser man I would have taken a stash with me to Siberia and changed them every few thousand km.
Correct me if I"m wrong :
For the SPROCKET HUB you need also 2x 20x42x12
see under number 5 and number 9
HTML:
# Part Number   Description lb Qty Each
05  36317708734  GROOVED BALL BEARING - 20X42X12 0.15  2   $30.69
09  36317708734  GROOVED BALL BEARING - 20X42X12 0.15  2   $30.69
