I have seen
a Basic
a Basic low
a Basic high
never seen anything other than a High version of a High...
if you can get a reading, its operational - if the reading is rubbish its the float position... later small tank bikes moved it to the filler neck (but not seen where it points to) - I guess the idea is to reduce the discrepancy between leant over vs upright readings....
the GSA has a setting to disable the readings when the side stand is down... the small tank bikes don't get that - my alternate float solution (as I have BOTH sets of wires but NOTHING to turn on in my Basic High) is the probeemer box - but if I park on the side stand with >15 litres in there it goes mad and throws the broken strip errors - then when upright gets over itself all over again within 200 yards - also takes 70+ miles to drop a notch, in fact next change is 3 bars gone, with 120 miles in from a full tank drops to nearly empty for 25 miles and comes back up to 70 to go ...and then works perfectly to empty - its just rubbish compared to a real strip
the Argentinian aftermarket strip is the correct way to go for small tank bikes
Fuel Sensor Tech shop
@MWH - if it says 480 then you have a GSA ? - If so did you turn on the second feature - igore side stand readings ?
a Basic
a Basic low
a Basic high
