Denzo,
Bloody good work.
Question:- does this conversion enable all the functions of the strip? I'm thinking specifically of the right/left side fuel transfer that the pump does using the fuel level.
I have a GS911 that apparently won't do the programming. IM in Zummerzet, can this be done off site after installation and is there someone willing to do it for me if I ride/bring the bike over? Beer will be involved...
Bikes an 07 plate GSA which I've had from new...
Fluff.
Might not work i'm afraid
the R1200gs Bikes from 12/02 - 10/07 (K25) with the type code 307 & 317 could be supplied either with float sensor or fuel strip
The trigger for which bikes got float( good) or strip (not good) was if the bike was specced with a trip / onboard computer option you got fuel strip
If the bike didn't have have the onboard computer specified , you got the pump / float unit
For the GSA (K25) 03/05 - 09/07 type code 0382 & 0397 the above also applies
For both varients GS & GSA from the model uplift in 2008 GS model codes 303 &313 GSA model codes 0380 & 0390 The only option was onboard computer so all fuel strips
From the model uplift in 2010 they went back to a float system
However there is overlap on the changes so bikes built / registered around model change dates may have one or the other system fitted
it is possible to change from strip to float, but it is also dependent if you have the right ZFE for the pin swap to be applied
The RT range does not have the right ZFE so can not be converted.
As an update to this
its all down to the ZFE - central ecu
Te ZFE come in 3 varients
Low
Basic
High
Depending on what options were specced depends somewhat on what pinning is in the ecu
The low zfe has pining for a float only - no onboard computer
The basic zfe i believe has pinning for the onboard computer but may not have pinning for the float system,
or if it does, the heater element which is used to calculate some of the onboard computer functions may not work, as it has been removed.
The high, i believe is the all singing dancing fully specced opttion
