Seized Oil Filter R1200RT (2007)
NeilH
Great Haseley, Oxfordshire
When I did the bike service the last thing that remained was to do an oil change. So the last service agent has clearly over tightened the filter or failed to apply grease or oil as part of the seal.
Before I totally go and burr or misshape the filter using the filter wrench, what have you done to overcome this. The oil filter is recessed and very little opportunity to do much.
I could drill 4 holes in the head of the oil filter wrench and try and put some self tapping screws in to secure it, there doesn't seem to be any space or very little access on the side to get a screws in.
Thoughts?
one of these
I actually do have one of those but is just tends to slip, I could put some double sided tape (Just thought about that) around the filter then try again!~ I would rather do that first than attempt drilling holes.
You could try,
drill 2 holes in your filter tool opposite each other , get 2 THICK 2in self-tapping bolts , fit tool , hit bolts through holes , undo.
Deffo . Get it as tight as possible and decrease the filter before trying
Filter tool Drill holes in from the top NOT The sides and screw in decent self tappers and give that a blast
Be thankful its not a 1200 Oilhead
Be prepared if its a cheap as schite Hi Flo to have the cylinder of the filter spin on the rolled joint of the flange!
Is there enough clearance to use this on the RT? Will the leg actually fit between the filter and engine casing?
I doubt it!!
The other thing you can do is get a half sheet of W&D sandpaper trim it to about the diameter of the filter + an inch in a circle
And set it into the filter tool and tap it on to the filter
Nice and Tight and then try to spin the filter off
With 1200 Hex heads the tightening instructions are on the filter but translated from french makes most sense
Tighten by hand until tight and then 3/4 of a turn more
Plus 3/4 turn sounds more than plenty.
I've usually found the recommended torque setting only adds about 15-20° after its seated on its seal
It is written in the instructions onthe filter by the manufacturer!
Tighten by hand and then a further 3/4s of a turn
And therin lies a problem,
A lubricated seal will tighten by hand more than an unlubricated seal
however your or my hand tight, will be way way less than my wifes hand tight.
Ive seen lads tighten a filter so tight, that the lip of the filter is touching the sump ! hand tight ;)
