Ah ok i misunderstood that part, i will have a look at a fix later
Sent from my SM-A202F using Tapatalk
for a gs rear indicators are 63231539680 fronts are 63138557204 they fit exactly as the older ones,new ones have a 4 pin plug,i ordered off ebay a couple of the chinese gs indicators to use the plugs from,so that the indicator part plugs sraight into the bikes original wiring.The runing lights\stop light section has 2 wires that on the new bikes must run through a control unit to vary voltage,as i have a can smart fitted i simply used on wire to piggy back onto denali pig tail for the b6 or b9 whatever aux brake lamp,now all works perfectly with no error messages and i can programme brightness and if req even brake lights to flash with hard braking
Not all 2021 models have rear running lights built into rear indicators. Mine doesn't have it. At least here in Portugal it was optional that I refused and kept my money for more beer and petrol.
A good riding friend has a Super Tenere with brake/running lights built into the rear indicators (been a Yamaha optional extra on the Super Ten for a few years!)
When I'm following him I often have great difficulty in seeing his indicators if he is braking at the same time. I hope BMs don't have the same problem.
Having said that it could be me.....I often struggle to see car indicators that are built into the rear brake light if the driver is braking and indicating
Mike
Can you provide photos of the front and rear indicators? Thanks.
Turned off. Thanks.Turned on or off?
so schoolboy error sorted,no more stop lamps in the indicators just running lights at 10% intensity
Mike
I've programmed both rear running lights in the indicators to go off when either indicator is on
Pretty. Is there turned on? Thanks.Here you go:
Maybe it’s just me but I think the rear running lights are less visible then the larger centre light.
Now if I could have all three lit, traditional rear centre and the two indicators.... though that may look confusing - like a high-level brake light that’s stuck on.
