- Joined
- Jul 14, 2010
- Messages
- 8,676
- Reaction score
- 467
Don't put yourself down, Tetley's started doing it.
Bad man!
Mikey that single tap will possibly not be able to feed both the Dellortos at full chat
It will Just about manage an 800 on bings
It took a while to figure out a running problem about 10 years back Until I figured that tank had been repainted and I asked the bloke and he said He couldn;t afford a twin tap replacement for his that had a leak So he bought that one cheap off a bloke that he knew who had it lying (A single tap)
Solution until he got a replacement tank was to use less than 4000 RPM for extended periods or when it started coughing to slow down and let the bowls fill up again
I tested it with my twin tap tank and it was fine
I’m not saying you are incorrect ,
However
