Another one saved from the angle grinder
mikeyboy
Overland and classic,vale of belvoir,Melton Mowbra
Was going to get hacked up for some kind of “ project”:blast
The rest of the bike will arrive tomorrow,
In the mean time,
“ can you tell what it is yet?”
:D
Definitely pre 78 but no idea other than that.
5 minute job for a man with a vapour blaster :D
/6
Looks suspiciously like my 1974 R75/6 which is in a later stage of nearing an expensive reassemble.
Engine had to be cut from frame and front engine mounting bolt drilled out.
Clutch needed replaced.
Tank, bikini fairing, mudguards and side panels with one painter. Should re ready in 2 weeks.
Frame, swinging arm, stands with another painter. Should be ready in 3 weeks.
Cylinder head exhaust guides and seats being worked on. Should ready next week.
Waiting on gudgeon pins which are in the post.
Battery box for powder coating, and chrome to be rechromed.
A work in porgress.
It took 10 tonnes in the press and nearly 200 deg of heat to get the pistons out.
And no,I didn’t smash the barrel skirt,
It’s a shame because I could have saved the barrels ,chimps:(
If anyone has a set of 1000cc iron liner barrels,shout up:thumb
...bloody heck mikey that's worse than mine ... but you are the right man to sort it:thumb
..just wish i had your knowledge and skills... i'm just bumbling along....:aidan
