Bit of a breakthrough today - managed to get the first mock-up of the dash done. This has been a massive PITA trying to make a simple plate to fit in the space and get all the gauges in.
This will do for now, and I’ll get it made up in 2mm alloy. Disappointed because I wanted a rally tower, but that just won’t fit with this fairing, unless I start cutting it up.
Maybe should bite the bullet and get the HPN fairing.
I’ve managed to clear the decks so to speak, so have some time to get back tho this beauty that’s been sitting under the covers n the workshop for a while.
first job is to fit the rear fender, then I can send the subframe off for powdered, and the seat off for recovering.
Just a basic Acerbis rear mud guard
Not forgetting to position it right for full suspension compression
Looks ok I guess
Need to remove the two tabs. Not in the right place
But these little brackets hold it on nicely
Looks ok with the seat on as well. And it doesn’t foul the mudguard which is nice.
Finally, confident that all the trialling of different options at Christmas mean I’ve got the dash bang on, I cut a nearly final option from plastic sheet and fit it.
B*ll*x, its shit. Angles are all wrong, can’t see the instruments standing on the pegs, and it looks crap.
But it’ll do to get the engine started and get the bike on the road.
Back to Plan A though and we’ll try and make a rally tower to fit.
Right, off to walk the dog and go for a ride on the Pan.
VERY impressive work and attention to detail. Where did you source the cable and cable stop for the inverted rear brake cable? I assume it's a commercially available solution?
