The deal is nearly done.
Another toy...
Two application process.....plasti-dip and 3M 5400 tape
Rider Magazine back in 2009 discusses the 4V designation and states,
"The factory’s dithering in deciding if this is four valves per cylinder or an eight-valve motor typifies a lack of organization which still needs to be addressed at Guzzi."
The plasti-dip is in spray can form and was used to cover the spoke ends. Sprayed several times into the holes over 24 hours so it gets quite thick. It’s sets like a rubber ballon. Then use 3M 5400 around the whole inner rim. Tape Not shown on the pics which were actually the first phase pics. Many YouTube articles refer to 3m tape as sufficient but others advocate sealing the spoke ends first by a sealant. Hence the plasti-dip (others have used boat sealant)
It seems to have worked and time will tell. If not it will be back to tubes and tyre tube sealant and spare tubes etc......but hopefully it has worked
Ordered the Centenario today. My missus thinks I've got a screw loose. she may well be right.
1 per dealer?
Is that in addition to, or are you trading your previous model?
It would appear that my initial thoughts may be correct. The V85 Centenario is not a limited edition, but a 'special edition' which will only be produced during 2021...
My V85 Centenario is here, well it's at the dealers. Due for delivery next week. Apparently it looks stunning in the flesh and the pictures don't do it justice.
It's in the window at Teasdales, I'm going to have to show great restraint not to go and have a look.
Teasdales have managed to get two. Mark says he's had about 20 serious enquires, but has been told there are absolutely no more. Time will tell.
