Anyone know where I can get a replacement or refurbed alternator?
I'm surprised no clever bod has worked out a way to weld the feckers back together
Or is it some obscure alloy blend which dosent take to welding
I would guess that something inside had corroded enough to expand and burst the outer case. I don't think a simple weld will fix these do you?
Forgive my ignorance Steppers but does it have any kind of cover above the new shiny part ( other than the tank)
I did take the tank off my last 1200 but can’t recall.
750 quid. Jesus.No cover above. the engine management ECU sits above the alternator, neatly angled to deflect any crap coming under the front of the tank straight onto the alternator .
There's a plastic shroud at the front but it does very little to stop anything from getting at the alternator, it's purely cosmetic.
