Wow!!
Lovely isn’t it?!
Wow!!
clocks .
Thank you! Here she is this morning at the MOT shop (no stand, so leant against the wall). She doesn't require an MOT due to her age, but it's a great excuse for a ride out!Lovely isn’t it?!
At some corners at Cadwell I need to shift down as well. Probably because I'm a novice.
You’ve moved the horn,
Do I get a prize?
No speedo required for MOT but for road use it must be fitted and working and within 10% accuracy.The MOT doesn't require it, hence it passing all the time, but the Road Regs require you to have one. It doesn't need to work or be accurate!
