Ive fitted my own this morning.
Honestly put everything aside for a day and go for it, its genuinely easy.
it takes longer removing the farings than fitting the denali stuff.
Take off front beak and the 2 side faring it tooks into.
Take both seats off
Take 2 screws out under seat holding tank cover in place.
Behind handle bars remove 3 more screws
cover for tank will lift off.
run light cables from the Cansmart box from under front beak, down side of tank cover.
under first seat and feed it under the devider to under the back seat (can be a fiddle)
Remove cover for battery, 1 screw watching for the 2 rubber rings rolling off.... they tend to try and run away lol
now the hardest part....
get the cansmart in place under back seat, insulation tape the 2 ends for the wires going to the battery (the ones with the inline fuse)
the tape is just so you dont touch anything while pushing through
feed it though the deveider between seats life before, only the other side... can be a bugger to get the inline fuse bit to go through... but it does.
get the wires to the batter... inline fuse to positive, the other negative... 2 screws.
unplug the plug right at the back under back seat. there is 2... unplug the one tucked under the very back.
Plug the can smart into the bike and the plug you removed from the bike into the cansmart (passthrough)
plug your lights in and check all is working.
If all is working.
cable tie the wires but dont snag and make sure the handlebars move freely.
Replace all fairing and job done
