You’ve cracked that, the bike sounds sweet now, great job
Well it's one less clacking noise.Yeah that looks really wrong, on mine that metal tip is tight against the aluminium shaft, and the loose one moved a tiny amount. They must have been rattling around in there like nobody's business.
Sent from my SM-G986B using Tapatalk
Thanks, I'll admit to being a bit nervous starting it up again in case I'd made a mistake somewhere and the engine ate itself.You’ve cracked that, the bike sounds sweet now, great job
https://www.amazon.co.uk/dp/B00EQ6QRF6/ref=cm_sw_r_cp_apa_glc_fabc_F3Y4CW91G90481KGAEMPThanks, I'll admit to being a bit nervous starting it up again in case I'd made a mistake somewhere and the engine ate itself.
As it is I'm happy there is now one less thing I need to pay to get done in future.
There is still a ticking noise coming from somewhere but I'll live with that.
If you listen closely at the end of the video, there is a humming noise.... Fuel pump, every now and then it Squeals really loud when I'm riding, usually if I'm riding motorway speeds or higher rev riding. Job for another day.
Will take for a spin later to see if the clack noise is gone when riding. That was the initial problem, I originally thought the Idle was smooth.
Sent from my SM-G973F using Tapatalk
Just the right side were visibly loose but I replaced both sides.Good work - going to so mine soon Did you do both sides or just the left?
Ah OK, is that normal? Sorry for so many questions, but I don't have another GS to compare against and my mechanic told me the bike sounded normal from the beginning.That's sounds like the injectors clicking
Great one less expense to worry about. Is it an easy change?https://www.amazon.co.uk/dp/B00EQ6QRF6/ref=cm_sw_r_cp_apa_glc_fabc_F3Y4CW91G90481KGAEMP
Fuel pumps are cheap...
Having just listened with earphones it sounds like mine does. The injectors click and they're brand new on mine as I upgraded to the 1200 ones. You can check that the pulley on the right side throttle body has no play in it as this wears sometimes and clicks. You can check it by putting pressure on it with your finger with the engine running and see if the clicking stops.Ah OK, is that normal? Sorry for so many questions, but I don't have another GS to compare against and my mechanic told me the bike sounded normal from the beginning.
Thanks for all your help.Having just listened with earphones it sounds like mine does. The injectors click and they're brand new on mine as I upgraded to the 1200 ones. You can check that the pulley on the right side throttle body has no play in it as this wears sometimes and clicks. You can check it by putting pressure on it with your finger with the engine running and see if the clicking stops.
As for the fuel pump it seems an easy job, the advice I've got is you may as well renew everything in there, fuel filter, pipes, clean the fuel gauge resistor track and replace the gasket etc while it's open. Be very careful not to snap the studs when opening as they are welded to the tank. 1 seems to be alright but any more than that and you have an expensive problem potentially unless you're handy with metalwork.
No worries, I've been given all this information from this great forum so happy to help where I can. I've only had my GS since Jan too hahaThanks for all your help.
I ordered mine through the local bmw dealership parts department. 130euro for the 4 including tax. They are the same as the r1200gs pushrods. To the best of my knowledge they are the only ones available now. I just ordered 4 pushrods and the new ones arrived.Great thanks for the information, were they new or second hand?
True, my bike is pretty quiet at idle but the the clatter continues when I'm riding.Earplugs are cheaper!
