FD2 Active member UKGSer Subscriber Joined Nov 5, 2013 Messages 204 Reaction score 5 Location Liverpool England Apr 5, 2021 #1 Anybody know of any airhead gurus in the northwest/merseyside area? Want someone to walk me through carb balancing.
scooter paul Well-known member UKGSer Subscriber Joined Dec 1, 2013 Messages 710 Reaction score 42 Location Surrey, England Apr 5, 2021 #2 If you can’t find someone to help there’s a number of good videos online explaining how it’s done. You’ll need a good quality carb balancer.
barny Well-known member UKGSer Subscriber Joined Jan 14, 2007 Messages 1,376 Reaction score 136 Location Tractor Central, Norfolk Apr 6, 2021 #3 You could try this it is well written and explains a lot. https://bmwmotorcycletech.info/bingcv.htm
r100gser Registered user Joined Jan 3, 2006 Messages 185 Reaction score 0 Location liverpool,england Apr 6, 2021 #4 This is quite informative for carb balance look just after the 45 minute mark...ian https://youtu.be/cRbaKhue-eo This might also be useful http://www.vintage-register.co.uk/library/Technical sundries/CV Carbs.pdf
FD2 Active member UKGSer Subscriber Joined Nov 5, 2013 Messages 204 Reaction score 5 Location Liverpool England Apr 7, 2021 #5 Thanks gents. The learning continues
mikeyboy Well-known member UKGSer Subscriber Joined Jul 14, 2010 Messages 8,676 Reaction score 466 Location Overland and classic,vale of belvoir,Melton Mowbra Apr 7, 2021 #6 Balancing a set of good carbs with a single pull cable should be straight forward. If the carbs are worn or need cleaning ,or are twin cable set up with poor cables,or bad routing itcan be a complete PITA.
