turned ignition on after a few month lay up. Nothing - no dash lights , no lights no ignition . Battery shows 13.5 volts. help please
thanks for replies. Just a matter of disconnecting battery 30 sec wait reconnect and do the throttle twist thing 3 times to reset ecu.
cheers
cheers
Maybe a corroded terminal connection causing the symptom of a dead battery.
Disconnecting and reconnecting possibly created a clean contact patch.
