GS para top yoke upgrade
mikeyboy
Overland and classic,vale of belvoir,Melton Mowbra
I’ll put this for sale once I’ve got some pics,
I’ve got a billet top yoke conversion for the earlier paras ,the one with the simple top nut as opposed to the later with the threaded stud/ lock nut arrangement.
Machined from billet,anodised black,with 2x fork clamp bolts instead of the standard 1.
The advantage over the oem,is the bar mounts are not cast onto the yoke,just a m10 hole.
So you can fit any height riser with 22 or28 mm clamps.
Pm if of interest,I’ll get some pics ASAP.
I’d be looking at £80 ish
Some pics of the yoke,
As you can see,it will enable the fitment of any height bar mount,22 or 28mm via the m10 rubber mount
£80 collected,add another £10 if you want me to pack and post
It looks similar to one I had in a couple of years ago,
If you find yourself looking to buy a bike like this,make sure you get a good test ride on it,
It looks like the fork yokes are standard ktm or whatever.
The lack of offset and change of rake and trail makes for a dangerously unstable bike.
Bought...
Mike confirms that this is 'just' a beefier version of the std set up - so no change to rake, trail or offset to worry about. Works for me - yet another bit of kit I didn't know I 'needed'...
