I have a WR250R sitting on supermoto rims. Recently changed brake lines & front pads and switched the disc on supermoto front with a larger 320mm version incl caliper bracket. Front brake now bites/releases/bites/releases/etc when lever is pressed. Tried cleaning disc & bleeding again with no joy.
Switched rims with oem 18/21's and both brakes work fine. The new disc looks fine, any ideas on what the problem could be, bedding in issue? Cheers
