I'm not chasing a red herring, I'm trying to find a solution which will keep the ABS. From what I can gather, there isn't a way of dumping the servo function but keeping the ABS, so I would ideally like to fix the system which has managed to work for 16 years, but failed because the fluid hadn't been changed.
As the rear servo motor runs, but it doesn't generate pressure, (or change it's tone when there is pressure in the system) it seems very likely that the motor and pump are disconnected. That's got to be easy to fix.I've got a lathe and mill if I need to make anything, but I don't want to spent thousands or loose the ABS.
You need to plug in the diagnostics and have the fault codes read.
There are two integral filters in the pump, one for front another for rear, i posted up about 15 years ago where i had success in removing them on a failed unit, cleaning and replacing, the servo/abs modulator worked perfectly. I posted a picture of the filter, it's location and how to remove it.
I thought i'd solved the continual problem of the units, but it was luck, tried it a on quite a few since and it might work on 1 in 20.
I had a german specialist who was going to recondition the units take away about 25-30 units i'd removed.
He found the main cause of the problem - apparently two discs which spin at huge speed and need a very precise microscopic gap between them, they wear and the gap increases and the pressure isn't constant ( that's roughly what i think he said, it was at least 10 years ago and he spoke very bad english).
It was fixable, but to be able to retail the units in Germany required him to put the units through a TUV test, at great expense, and then he had to offer a guarantee, and due to the design faults in the unit meant a high turnover of replacements, making the whole exercise not financially viable.
I've got about 40 units sitting here, later today i'll get some pictures of removing the filters etc and post them up. be quicker than trying to find the old pictures somewhere on my hard drive
