Typical,
I had a sound bomb split which i purchased but never fitted to the hexhead,
I sold it, as it appeared a right pain to find somewhere to fit the compressor, and get a feed to the horn unit
I then picked up a compact thinking it will fit in between the forks with the correct bracket.
Watched an install video this morning on it's "A bike thing" and he was saying that the compact will not work with lowered models as it will get belted if the front end goes
into full compression - ala if you go offroad .. FFS
So the question is, Has anyone fitted a compact to a lowered GS ? and does it get belted on full compression , or is it ok in non offroad conditions
Or do i put this one back up for sale and try and locate a split again ??
