What do you think?
They need to be on the bike out of the throttle bodies aimed away from the injector holes (maybe into a jug) with the engine spinning over and checking the spray pattern
Your eye will tell you nothing
It is also worth upgrading to the 1200 injectors as sold by www.tills.de. They are an improvement!
You can clean them yourself with a can of carb clean and an oblong 9 volt battery.
I don't know if they still do, but Bosch used to have local agents / service centres
where you could send you injectors to for a refurb / overhaul
For more or less the same price, I'd rather go with new ones, no?
You need to diagnose the problem rather than throwing money at parts That you may not need
What is the problem with the bike and why did you remove the injectors ??
Si sera plus facile d'expliquer tu peux ecrire en francais
Next step will be crossing injectors. And changing spark plugs too.
Oulala, il est si mauvais que ça mon anglais
do NOT touch the small 7mm screws on the inner sides of the throttle bodies
Which one are you talking about?
https://www.realoem.com/bmw/fr/show...21-BMW-R_1150_GS_00_0415,0495_&diagId=13_0840
Check the resistance across the injector electric terminals. It should be around 16.
Ç'est très difficile à montrer sur cette Microfiche
Regarderdez la fleche rose
Jamais lui bouger, parce que il est regule a l'atelier chez BM en fabrication
Ils sont derrière des mechanism du câble chaque côté
