Had both front & rear brake fluids changed on my 2002 R1150 GSA with working ABS at a local non official BMW Motorcycle repair shop, after collection and 200km the ABS failed when riding and I have the alternating flashing lights and no ABS. The technician working on my bike had several other jobs to do including fitting a new Gear Indicator switch, for
each job he took photos of the work in progress and at completion so I could understand, however, I have just noticed from the photos that when the front & rear brake fluids were changed the fuel tank was NOT removed from the bike, which means the abs module was not bled, could this cause an ABS failure with a stuck piston (GS911 Fault Code).
