Options as I see it are the Acewell CA85 or the Siebenrock GS2 for my R80g/s ... what's the best choice
Keeerrrrrchingwhat's wrong with an original?
Just asking.
Certainly no mot fail here,not even tested.Are GPS speedos actually Legit
I think there is an MOT fail for this over here If they work out its a GPS one
Remember we have Government test centres not like your garage ones
What would be a reason for legal/ mot issue?
GPS Failure = No speedo
They won't let you use a separate mounted GPS here for your Kmh on MPH only speedo bikes Eg American R1100RTP import I took to test about 7 years back
They also won;t let you have stickers on the glass as the markings have to be illuminated they have to be in the clocks
Think about us poor feckers over here next time you bitch about your MOTs
Keeerrrrrching
I’ve got one but it’s in KM
Speedometers
35.—(1) Save as provided in paragraphs (2) and (3), every motor vehicle shall be fitted with a speedometer which, if the vehicle is first used on or after 1st April 1984, shall be capable of indicating speed in both miles per hour and kilometres per hour, either simultaneously or, by the operation of a switch, separately.
(2) Paragraph (1) does not apply to—
(a)a vehicle having a maximum speed not exceeding 25 mph;
(b)a vehicle which it is at all times unlawful to drive at more than 25 mph;
(c)an agricultural motor vehicle which is not driven at more than 20 mph;
(d)a motor cycle first used before 1st April 1984 the engine of which has a cylinder capacity not exceeding 100 cc;
(e)an invalid carriage first used before 1st April 1984;
(f)a works truck first used before 1st April 1984;
(g)a vehicle first used before 1st October 1937; or
(h)a vehicle equipped with recording equipment marked with a marking designated as an approval mark by regulation 5 of the Approval Marks Regulations and shown at item 3 in Schedule 4 to those Regulations (whether or not the vehicle is required to be equipped with that equipment) and which, as regards the visual indications given by that equipment of the speed of the vehicle, complies with the requirements relating to the said indications and installations specified in the Community Recording Equipment Regulation.
(3) Instead of complying with paragraph (1) a vehicle may comply with Community Directive 75/443 or with ECE Regulation 39
My Siebenrock lets in moisture
The size is the same I believe but the fitment is very different. From memory I think the odometer reset is on the side of the ST not on top.I believe that the Siebenrock speedo is made by Acewell, but could be wrong (it does happen, very rarely!)
Does the ST speedo fit the g/s? Does anyone know, or are they different sizes?
Keeerrrrrching
