T7 suspension
Hello
I swapped the rear spring first 90nM kg good .BUT
I then at the start of 2021 installed the Rally Raid open cartridges.
Installed them myself, easy to follow instructions .
On smooth tarmac I cannot detect a massive difference we’ll not £700 better.
On broken tarmac and rough surface they seem a noticeable difference and
You can set the pre load with Rally Raid.Worth £700 ???
Only you can decide.
I finally changed the rear shock for a Maxton unit .GP10 shock .
Custom made to my spec,no need for hydraulic preload easy to adjust on bike .
Just under £950 and this unit has made in substantial difference very plush/compliant but when control is required over loose surfaces amazing.
Worth £900 +++ Maybe ,maybe NOT.
When and if I sell my bike all can be returned to standard and all this expensive crap can be sold on for good money ?
