Shock absorbers
Yes they will, I’ve fitted them to mine. You will need the side stand and centre stand off the adventure too. When you’ve fitted the shocks, check the the front brake hose isn’t being strained with the bars turned to the left. Also check the rear brake hose because the swingarm will ‘droop’ a bit lower with the GSA shock. Mine were a bit strained so I fitted the front and rear adventure brake hoses as well.
