Switzerland - South / south west - Sion / Martigny / Visp
Wapping
Moderator
Moderator
Wapping, London
Quite a nice jaunt, along what is basically a straight line, with branches off up valleys, all courtesy of Alpentourer magazine 4/2021.
Downloadable, as usual:
https://www.alpentourer.de/alpentourer-tourentipps/gps-2104/
if you fancy visiting this area then my friends Bruce and Judith have some apartments in Morgins on the Swiss/France border, just a few km west of Monthey on the map above.
http://www.chaletbeauroc.com/
Bruce is a fellow biker.
A good tip from Wessie.
Morgins to Martigny, is only 35 minutes, straight down the motorway.
The run up that valley is really torturous, or was last time I did it (2010) but if I had to go that way again then it would be great to run up and down some of those dead end valleys as I expect tehre are some real hidden gems, the fact the roads never make it over the top of the mountains hints that they might be quite spectacular.
I also found this, which is broadly similar but has the possible advantage of being circular.
