Hi guys,
Last week Garmin replaced my BMW Nav VI, originally purchased May 2018, for the 4th time. The usual problems (ghosting etc), replaced by a supposedly new unit which, immediately exhibited the same problem. Those replacement units came as stand alones in plain wrapping. I suspect they were refurbed and not new.
Last week Garmin's latest replacement arrived which they said would be a 'Refresh' version. And so it is, presented in a new sealed box with all the accessories included. It is certainly different software, presentation wise (version 10). Whether the screen construction is new is yet to be decided, though I suspect it is. This is of course subjective without an original Nav 6 to directly compare with, but the screen seems clearer and certainly quicker to refresh. Apart from that and the monochrome menu most things, so far, remain the same as before.
Now, my Samsung S21 (android), BMW TFT, N-Com (Sena) 902X combo connected in that order works well. The BMW Connect App IMHO is both impressive and useful. Yesterday I added the new 'Refresh' Nav 6 to the mix and paired it with my headset disarming 'Calls' and 'Contacts' to avoid, I hoped, conflicts prefering to use the TFT for calls and media controlled by the Wonder Wheel. Initially all was good receiving clear turn by turns from BMW Connect and 'ding' alarms from the Nav 6 when approaching speed cameras for example. I then changed over from the BMW Connect navigation to the Garmin Nav 6. Again all worked well, especially when the Nav 6 volume was turned down to 40%. (any higher created distortion). Clear turn by turn etc. I then went back to the BMW Connect Nav and could not get any voice from it. Clearly there is a conflict. If anyone else has experienced this and has a fix I'm all ears .
Stay safe and well.
Best regards,
Tony.
Stay safe and well.
Best regards,
Tony.
