Love my Roadlok, think its a great design and use it a lot.....however, during recent holiday in Scotland, used it with bike on side stand and just a bit of a slope. I generally always use centre stand . ~This time, i rolled the bike in first gear until the roadlok pin engaged, then left the bike (steering lock on as well ).
On return, key in Roadlok, lock unlocks and pin springs out about 3mm and STICKS solid. no amount of pulling will release it completely. Bike stuck solid, cant move it to get on centre stand, rocking back and forth doesn't release the pin. Can't rock bike and pull pin simultaneously.
I was lucky to have assistance to heave the bike onto the centre stand, then just wiggling wheel released the pin.
experimented later in evening, same conditions, side stand, etc but with a 3rd hand to pull the pin. As i "rocked" bike back and forth, pin came straight out with minimal pulling force. I say "rocked" because bike doesn't actually move, i was just removing pressure on the lock pin.
Everything in the lock/pin/body is clean and moves freely. I've concluded the pin jams because the pin wiggles very slightly in its larger diameter silver body; not faulty or worn , just design tolerance. when put under "twisting " pressure, the pin jams in the larger silver sliding body.
So just a warning to all.....keep this in mind , i'd have been stranded without help.
