How many owners notice the traction control light come on regularly?
When I first test rode a TC (circa 2011) they had given me a warmed up bike and I instantly noticed its misfire / hold back within 200m of the dealership. As I got more used to the bike and the roads quietened down I realised it was traction control interference on any large throttle application around 4k mark. Swapping to what I thought was "sport" (for all intends and purposes) made it ride down the road with throttle cable correctly making the back wheel turn as instructed by the rider
Having just had ASC added to my old 2007 bike running sporty road tyres its the same. It will interfere at any point in a straight line under full acceleration when there is no possible hope of a loss of traction. BUT I have found this is only when you corrected the horrendous wrong fuelling.
Set up the way BMW do it the bike can't make enough power to make the TC cut in. But correct the over fuelling so it runs correctly and TC is on all day long. So you must select S mode before trying to ride the bike. The other dangerous issue with the default setting is pulling away it frequently has a moment and just dies - leaving you stranded and in dangerous situations. In S mode this can't happen, the bike is just safe with some extra drive line protection as you smash in and out of the craters we call roads.
