As suggested unplug the AF-XIED`s at the plugs that come from the GS`s wiring loom, it will take the lambda sensors and the AF-XIED`s out of circuit and the ECU will default to a setting of lambda 1,0 which is an AFR of 14.7 to 1.
It will give you a starting point.
Or download the GS911 software after plugging in the GS911 to the laptop via USB . when the GS911 is plugged in to the bike you will be able to see the output waveforms' from the lambda sensors, there are examples on the Hexcode website.
