BMW R1200GS TE 2017 33,000mls
My bike has started making strange noises from the under seat/behind the engine area.
When the ignition is turned on I get the usual pump priming noise but is is slightly rattley. More strangely when the ignition is turned off it sounds like the pump? is pulsing, on for a second then off for 3 seconds, this is repeated for a minute or so then stops. This happens when the engine has been run, or not, hot or cold and with the kill switch on or off. The bike seems to be behaving normally otherwise.
It sounds like an expensive trip to the dealer.
