Parts ...
Clutch friction plate replacement | CLA25352 1 63.00 63.00 63.00
Clutch bolt | CLA54417 6 2.10 12.60 75.60
Clutch bolt washer | CLA42377 6 0.65 3.90 79.50
Clutch diaphragm spring | CLA42353 1 36.84 36.84 116.34
Clutch actuation pushrod felt seal | CLA30440 1 3.00 3.00 119.34
Used - Clutch actuation piston | CLT64167 0 18.00 0.00 119.34
Input shaft 5 speed complete R1100GS GET45512 1 95.00 95.00 214.34
BMW exhaust clamp EXA41478 1 21.60 21.60 235.94
Used - Clutch p'rod steel with groove | CLT40391 1 17.00 17.00 252.94
Motorworks PnP 3.90+4.30+4.80+5.50 18.5 18.50 18.50 271.44
Pilot bulb 4 watt inside headlight | LIA63576 1 0.90 0.90 272.34
Throttle body to airbox inlet duct O-ring | FUA41797 2 1.99 3.98 276.32
Crush washer bevel box filler SIA63200 1 0.32 0.32 276.64
M8x30 ssteel allen head bolt (silencer) SSA10479 1 1.02 1.02 277.66
M6 cage nut many uses | FRA26511 1 2.26 2.26 279.92Total
279.92
12.0 360.00 639.92
Hours Cost Running
279.92 279.92
Labour 32.7 986.00 1265.92
% £ 1265.92
discount (NATS) - % age on labour 10 98.60 -98.60 1167.32
to account - method date amount
0.00 1167.32
0.00 1167.32
0.00 1167.32
sub total 1167.32
powdercoating 23-Sep 50.00 1217.32
parcel away 26-Aug 32.98 1250.30
1250.30
1250.30
Total 1250.30
1250.30
Balance 1250.
20th 1.1 33.00
21st 1.3 72.00
2.4 144.00
23rd 0.5 159.00
2.9 246.00
1.2 282.00
24th 2.0 342.00
Sep 1.7 393.00
23rd 0.5 408.00
2.5 483.00
24th 0.8 507.00
0.6 525.00
0.7 546.00
1.4 588.00
0.4 600.00
25th 600.00
1.9 657.00
2.5 732.00
1.0 762.00
27th 762.00
762.00
1.9 819.00
0.8 843.00
28th 843.00
843.00
843.00
2.9 930.00
0.9 957.00
957.00
0.5 977.00
0.3 986.00
986.00
986.00
986.00
986.00
986.00
986.00
986.00
986.00
986.00
986.00
986.00
32.2 0.5 986.00
Repair rear light captive nut & fit a new one too, refit toolbox, torque subframe
& crash bar bolts (note 9) refit (broken) seat lock, secure wiring with tie-wraps,
refit pannier carriers & rear footrests. Fit sump guard, fill & bleed rear brake.
Sync throttle, which didn't work well due worn butterfly shaft in left throttle
body.
Refit fuel tank etc
Refit rear ABS lines and rear calliper, loosely fit front footrests
Clean & refit new clutch, fit gearbox
Glue rubber mounting the refit battery box
Retrieve seat sub-frame, refit same & begin reconnecting wiring etc
Fit new gear indicator switch seals, refit same.
Clean and reassemble clutch operating piston & arm, set clutch free-play
Remove old & fit new (supplied) swinging arm bearings, refit swinging arm
Remove fog lamp wiring from fuse/relay box. Refit fuse box.
Torque rear wheel bolts, fit rear brake calliper. Check fastener security
Labour type
Remove rear mudguard, pannier carrier & fuel tank
Modify rear wiring harness, drain rear brake, drain & remove bevel box
Remove rear sub-frame (nb swing arm pivots reluctant to loosen)
Refit RR mudguard, loosely fit luggage carrier
Refit left TB with new O ring, loosely refit crash-bars & subframe bolts. Refit
rear shocker and bevel box (note 6)
New bolt for silencer, secure ABS pipes & Lambda wiring, refit offside throttle
body, engage subframe bolts. Attempt to free broken screw in rear lamp unit -
note 8.
Clean & refit g'box drain plug, refill g'box with oil (supplied)
Refill bevel oil (supplied) note 7. Adjust bevel box bear's refit silencer
Strip sub-frame transport to powder-coater
Remove swing arm by cutting through pivots on each side
Remove gearbox and clutch
Fabricate transport pallet, investigate spot light wiring.
£1250 parts n labour not including the gearbox rebuild by mikey which was jus under £500
