PHILIPHUW
Got a tough one for you to crack. For many years I have been setting up my carburettors using a homemade u-tube barometer. Basically, some clear plastic tubing with some oil in it fixed to the garage wall. It always worked a treat. Lately, however, I’ve hit a problem. If I balance the carbs this way, so that the oil levels in both sides of the u-tube are the same, the bike runs rougher than a badger’s you-know-what. Setting it up “by ear” or using the plug shorting method, results in the old girl running as smoothly as Swiss clockwork, while the oil levels in the u-tube are inches apart. Recently had the carbs apart to do a rebuild with the repair kit from Motorworks. Made no difference. Also replaced the rubber carb to head tubing thingies in case they were leaking. No difference. The right hand cylinder/piston is a relatively recent replacement, with new rings. But they should be run in by now. And its not as if I cannot get her to run smoothly. Over to you lot!
