- Joined
- Dec 20, 2004
- Messages
- 33,547
- Reaction score
- 469
The HSC on my 2018 was easy to stall without a gazillion revs but the 2021 1250 works very well.
The difference is the 1250 works smoothly and the other you have to rev the tits off it and force the wheel to turn slightly ?
Knutt will probably be able to shed some light on this phenomenon.
Sent from my SM-G981B using Tapatalk
knut has it in one. The Hill Start Assist on my much heavier 1600 GT works a treat.
I did watch some hapless fellow on a 1250, rolling backwards down a steep Alpine slope, twice or three times. His mistake was to pull on the front brake lever, releasing the HSA before the system had done its thing. Leave the brakes alone (the bike isn’t going anywhere), give it some rev’s and let the clutch out. The brakes will release on their own and the bike will move forward, with no more rider input required than that. It is not very difficult.
On mine you have to double pull the front brake quickly to engage the hill start brake.
otherwise it just acts normal.
Now the worse part is, sometimes you double pull and it doesnt kick in, you roll back, and try again
its a bit of a fiddle.... well actually its crap.
Try just pulling it tight and holding once.
ffs its not difficult. you can use it if you want or if not simply dab the rear brake and it switches off leaving you free to hold with your strength / clutch / brake or whatever you like!
Barry
