Well, I guess I see a GS as a two wheel LandRover.
My Discovery 4 sits in the drive most of the week, it goes shopping perhaps once and my Mrs takes it to the station & back if she has to go into the office. It’s fully loaded with electronics, and has an adequately large battery. That said, if you turn off the engine and listen to the radio, it’ll turn it off after about 10 minutes to protect the battery.
My GS, (13 months old, no battery issues until 3 weeks ago) on the other hand, is used every day (unless it’s is pi55ing down and she’s not going to town, then I’ll take the Landy, I’m an enthusiast, not a martyr) for a 10 minute each way commute.
I’d hope ten minutes drive would replenish the battery from starting, though I guess it might be marginal if the heated grips are on. The voltage with engine running is 14.4 or 14.5 which indicates a good alternator.
The last time the bloody thing failed to start was last Wednesday - on Friday I did a 70 mile ride, I guess we all think it should be well, thoroughly, fully charged after 70 miles?
I didn’t use it over the weekend, and had to go away Monday night, so it sat unused until Wednesday. And simply would not start. In my view that is entirely unacceptable. Particularly as the weather is still pretty warm, if it’s failing now at 15C, we’ve got no hope at 5C.
The BMW tech says “you have to trickle charge it, the Tracker runs the battery down”. Well, it does, but according to Datatool, it uses just 0.4mA - that means it would take 250 hours to run the battery down 1Ah - more than 10 days.
I don’t know how much charge is needed to start the bike, I’d expect 80% should be enough. The battery is 11.8Ah so probably more than 20 days…
The other thing I don’t know is whether the Datatool is really asleep - it certainly uses more if not asleep though I don’t know how much.
The BMW website says “if you’re not using your vehicle for 4 weeks, trickle charge it”, and this seems reasonable to me - 4 days is a long weekend away, when you might not use the bike at all - and might not have anywhere to plug in a charger anyway. Perhaps they’ll start selling very long BMW extension leads to go with the BMW smart charger!
The bike is currently in Chandlers in Brighton for its 12 month service following a 77 mile ride yesterday - let’s hope it doesn’t start for them on Monday morning, and they fit a new battery under warranty. Preferably a lithium one, as I don’t think 11.8 Ah is close to adequate for three years warranty period on a large motorbike.
(My 44 year old Guzzi has a 32Ah battery, it’s bigger, heavier, and doesn’t let me down - I rate reliability much higher than the marginal performance gain of a weight saving of a kilo or so)
Will update when I know more
