R1150RT, hall sensor problem.
HES removed from bike and wiring checked out fine.
Upper Honeywell sensor operating the fuel pump is damaged. Looks like the metal has been worn off by the rotating lower pulley part. Hard to explain, but essentially need to remove and replace the Honeywell sensor.
Motorworks have no used hall sensors in stock.
I have put a wanted advert on the forum but no response to the advert. Anyone got a complete hall senor with the 2 x 3 row connection for sale.
Alternatively a damaged wiring setup where the 2 sensors could be reused.
