Brake failure warning
Swansea Jack
Member
Wales
Had this this morning,ideas please
Year off Bike would help But I suspect a Post 2006 with the later NON servo ABS
It usually means that your brushes are stuck and not contacting the motor windings
If it is a Non whizzy brake model it is safe enough to ride as they did away with the 4 brake circuit system of the servo brakes
2005 servo braked model
If you do a search here you will find shed loads of info on this as it's been done to death :thumb2
If you can get the OBD fault codes read, you would have a much better idea of what is causing the fault lamp. If the red triangle isn't lit up I would guess that it's not a serious problem, could be as simple as low fluid in the internal reservoirs.
Bike
Bikes going into the local bike guy to sort it out on Thursday ta for all advice
