Beebop
Hi guys.
Greetings from a wet and windy South Africa
Thought I'd draw on the collective wisdom here to help with a strange set of symptoms.
'04 1150 Adv, 186000km, mostly problem free.
On Saturday I replaced front and rear tyres and gave the bike a much needed wash.
Parked it on the centre stand and left it till I needed to start it for work today.
I got on fired it up and started moving, only to notice the triangle warning light was on.
I figured it may be something to do with the ABS sensors and the tyre change, so I ignored
it for tonight when I get home.
Then I noticed that the indicators are not working. I played around a bit with the switches and
noticed that when I switch on the heated grips, the ABS light comes on and the indicators work.
As soon as I switch them off, the ABS goes off and indicators stop working.
Obviously something to do with the right side switch cluster. Could this be water ingress?
What is common on these which I could look at without trawling over the wireing diagram, at
which I'm pretty useless.
All assistance would be appreciated.
