You've a point, but check out the price of Indian accessories and parts. They make HD look like a bargain.
Check your build dates…. Bikes built after May 2019 had the primary vent installed at Factory.. ( according to HDForums)
Pre May 2019 needs doing… can be done by “request” it seems
Just checked mine (a June 2019) and the vent is installed. No idea if that was a factory fit or done by the Dealer afterwards!
Wouldn't it just be easier & more sensible to buy an Indian?
More jam than Hartley's you.......
Result… fingers crossed for Doc..
The door is over there….. 3rd left……
Cheers Twizzle.
I will check vin plate tomorrow. I have a feeling it has not been done but no worries if it hasn't.
I will phone dealers Monday to arrange to get it done for peace of mind.
No way am i doing it. I do have a drill though and some old masonry bits.
And cheers Big Si. Your a good un.
It’s easy to check Chris, just watch this video and you’ll see where the tube comes out on the bike. Then just go look for similar on your bike - simples!
https://youtu.be/l8g4xxXNuus
I agree with your though, if it’s not been done get the Dealer to do it as it looks like you’ve got to drill just in the right place. All the risk is with them then!
OK so some of this makes sense but I’m still a bit confused and got a couple of questions
Phil - you say you fitted a vent to the crankcase. Did you do that yourself or did a dealer do it, and what was the reason for it?
I’m also interested in what’s happened with your brother’s bike. I think it’s slightly older than yours and you said it used to suffer quite a lot of oil movement between the transmission and primary. Has he taken it to a dealer to have the vent fitted and did that make any difference? I’m guessing he has also not had any gearbox issues either?
The oil filler vent was a test, there was talk of excessive back pressure within the crankcase causing oil to be blown through the air filter breathers and causing excessive carbon build up on the pistons. Venting the sump via the oil filler cap is supposed to reduce this and also ‘free up’ the motor. Personally I didn’t notice any difference positive or negative.
My brothers bike was a 2017 and suffered badly from oil transfer. We fitted the primary vent (simple job) as mine had no similar problem with the vent installed, and it did appear to fix the problem. His bike had some significantly less mileage than mine (circa 5000 when we left for Spain as opposed to the 15k on mine.
I’m still amazed that it has transferred from the gearbox as it hadn’t previously.
That does seem odd!
Did you have the Primary Vent fitted on yours too Phil, and was it a factory fit or afterwards (I think yours was a 2019 like mine)?
I think I will keep an eye on my levels going forwards, which I know you’re supposed to do but I haven’t really bothered in the year I’ve owned it! I shall do now though!
Phone the dealer Si, tell em not to deliver if not done….. get them to retro fit..
Mine's coming from a Honda dealer in N.I. The sale chap that I am dealing with apparently used to be dealer principle at Belfast H-D who supplied the bike new. He therefore "knows" the bike and tells me the "fix" has not been done as the bike has not displayed any symptoms so far. H-D Ireland's (North & South) policy has been not to offer the " fix" unless the bike was noticeably suffering from the oil migration issues.
He knows and I know that the vent fix retails at approx £50, he has knocked that off the final deal figure. I can therefore buy the components and do it myself or get my local dealer to do it. I will get it done just for peace of mind, and have asked the service mgr. at Cheltenham H-D for a price (he is on holiday until Mon). If it's silly money I'll do it myself. Ultimately I'm not losing sleep over it, the issue, whilst not rare, is easily monitored ( provided you know to look for it) and hopefully, a few reasonably inexpensive steps can sort it.
Cheers Twizzle.
I’d buy the fat clutch rod also to be doubly sure if I had my time again.
Mine had the vent, and it started completely transferring randomly, the thicker rod is an extra security for £100 ish
Most posts on HD Forum say the fat rod is a waste of time.
