Gearbox Bearing Numbers
Just the faulty heated grip and tyre pressure sensors to fix and the LED headlight cluster to fit and it’s all systems go.
Let us know how you get on - One of my heated grips has packed up, just waiting for it to be a bit warmer in the garage before attempting a repair
I recently cut the grip rubber back and tested it with no faults found so replaced the grip rubber. It then worked fine again but now has failed again so I’m just going to replace the grip entirely it’s had a good innings.
