typically Japanese, once they focus on things they tend to do very well - fancy doing a three year average and maybe rank how dangerous - I think BMW come out tops
don't forget - the world ended its all just shit now - its only marketing pretending there's a viable future
this is a nice one
Week 19 – BMW – R NINE T, R1250GS, R1250RT, R1250R, R1250RS, K1600GT, K1600B. The affected vehicles were manufactured between 31 October 2019 and 30 January 2020. Due to inappropriate materials’ characteristics, components may come into contact with the spokes of the rear wheel. This may lead to loss of control over the vehicle, increasing the risk of an accident.
Week 14 – BMW – C 400 X, C 400 GT. Production dates: Between 08.03.2018 and 18.01.2020. The position of the Bowden cables in the throttle grip allows water to accumulate in them. When driving at temperatures below freezing point, the cables could become sluggish or even freeze, affecting the throttle control and increasing the risk of accident.
or the year before
Week 43 – BMW – K 1600 GT, K 1600 GTL, K 1600 B. Model year: 2015-2019. The affected vehicles were manufactured between 22.09.2015 and 26.09.2019. The functional “shift fork / selector sleeve / gearwheel” group of the gearbox might become damaged. Consequently, two gears might be engaged at the same time causing the rear wheel to be blocked, or the teeth of the gears sheared off, increasing the risk of accidents.
Week 43 – BMW – S 1000 RR. Model year: 2018 to 2019. The affected vehicles were manufactured between 05.09.2018 and 27.08.2019. The strength of the material of the inlet and outlet hoses in the oil cooler is inadequate. Consequently cracks might build at the connection between oil hose and oil pipe, leading oil to leak on the rear wheel, increasing the risk of accident..
Week 39 – BMW – G 310 GS, G 310 R, C 400 GT, C 400 X. The affected vehicles were manufactured between 21 April 2016 and 08 August 2019. Surface corrosion could occur within the non-anodised calliper piston bore. Corrosion on the surface of the calliper could impair the piston’s clearance within the bore, affect brake performance and increase the risk of an accident.
Week 36 – BMW – S 1000 RR. The affected vehicles were manufactured between 9 May 2019 and 7 June 2019. Defective drill hole may restrict the oil supply to the gearbox. This could cause damage to the gears and blocking of the back wheel, increasing the risk of an accident.
Week 35 – BMW – S 1000 RR. The affected vehicles were manufactured between September 2018 and March 2019. Some of the supply and return pipes of the oil cooler were incorrectly moulded. As a result, the oil hose may become detached from the fitting and oil may leak out, increasing the risk of an accident and fire.
Week 15 – BMW – C 600 Sport, C 650 Sport, C 650 GT. The affected vehicles were manufactured between 09 February 2011 and 23 August 2018. The front brake hose may get damaged over time, which may lead to a loss of brake fluid. This can reduce brake performance, increasing the risk of an accident.
Week 4 – BMW – F 750 GS, F 850 GS. The vehicles affected were produced between 14.5.2018 and 12.11.2018. The connecting rods in the engine have not been correctly fitted and may lead to engine defects. This can increase the risk of an accident.
