Further to my 200m ride thread, I’ve finally had time to sort out this issue on my bike.
What I found seems to me to have likely been caused at manufacture so I’ll post the essential information here.
The pedal lever (1) pivots on the bush (3) which is held tight to the frame by bolt 6 located behind the right footpeg.
The bearing surface inside the lever is fitted with a sintered / porus bronze type material bearing surface which as far as I know is designed to be used with oil. The oil sits in the pores and ensures that the bearing surfaces are well lubricated.
What I found is that a particularly thick grease had been used at assembly and this had collected dirt and thickened up to a nice strong glue binding the two together. Foot pressure was sufficient to depress the lever but the return spring was not strong enough to pull the lever back up.
The remedy was to remove the lever / pedal from the bike, clean up the steel bearing surface and polish any corrosion with some fine silicon paper. Also, using brake cleaner, try to get as much gunk out of the porus bearing material as possible. This worked OK too.
With the bearing surfaces lubed with engine oil and the whole thing put back on the bike, the brake pedal now works perfectly.
Why they used grease we will never know
https://www.realoem.com/bmw/enUS/showparts?id=0J93-USA-12-2019-K50-BMW-R_1250_GS_19_0J91,_0J93_&diagId=35_0380
