Good to know, I'm not sure if the R and R9t have different housings. Have a feeling I need the casing that goes with the light. I don't suppose you have a link to the canbus decoder you used? Thank you for your help.Headlight casing and bezzle was all ok I had to bend the metal retainers a little to allow them to fit in and hold the headlight in
the canbus decoder is a must as when I got it working all ok I tried it without and once again the error was straight up so put it back in then it was all ok again
Rob
Sent from my LYA-L29 using Tapatalk
