marcusdav
Hi There,
This is my first post and here I am begging already!
I was hoping some savvy person can help me sus this out!!
About 3 weeks ago, got off the bike to fill up the petrol, got back on, pressed the button to start the engine.......nothing! After a lot of messing around, I managed to get a battery boost from the guy in the garage and got me started to get home. Right! time for a new battery I think. The next day I sort one out and off we go. I thought my problem was solved.
Well, anyway, about 3 days later, same problem.
Ive done a lot of searching around, a lot of reading. I got a multimeter and did all the tests on the stator/altenator and everything seems fine. 0.2ohm between each pin, no current detected from a grounding tests and the unit is pumping out 70 VAC at 5000 RPM.
Ok, so I move along the line to the voltage regulator and test the outputs, ok, here I am getting less than 1 volt (0.85) with the engine running. This must be my problem right?
I order a new voltage regulator, it comes in the post, I throw it on the bike and go to check the output, now im getting 15V. OK, must be sorted. But then I check the voltage across the battery with the engine running, im barely getting 12.5v . Thats not right as all the guides are telling me it must be at least 13v.
I took the bike to work today, its a round trip of about 90km, when I got home and tested the battery, it was barely over 12v and my battery charger is saying the battery is about half full. I must still have a problem right? Except now, with the stator / altenator double checked, I have not a clue where to look next.
I would greatly appreciate any advice.
Thanks!
Thanks!
