The RAC package of assistance is just a bolt-on to the Motor policy ie. Something stuffed into the same envelope as your certificate of Motor insurance.
The RAC operate a perfectly competent breakdown service in the UK and, through local agents and network partners, abroad in Europe.
Is there any ‘small print’ that will affect you being helped should you breakdown? Read the cover that the RAC provides. Having read it, what do you think?
Do the RAC or other competent breakdown service providers give ‘better’ cover if you buy it separately? Lord knows, as you’ll have to do a comparison yourself.
Has anyone ever had a problem being rescued by the RAC or, for that matter, any other competent breakdown assistance company? No doubt yes. There again, some complainants maybe have problems getting assistance to tie their own shoe laces.
What is the procedure? Most of them work the same way:
A. You have a problem necessitating a call. For example, your vehicle has spat its coolant down a mountain pass.
B. You telephone the emergency number and speak to someone. That someone may not be English but they will speak almost perfect English. Why are they not always English? That’s easy. The RAC need to employ the services of local language speakers, so they can assist you to find someone to help you in a Slovakian dialect, Finnish or Portuguese. It would be stupid if they only employed English only speakers from Hull or Penzance.
C. You explain your problem to them.
D. They set the wheels in motion to assist you, as detailed in the booklet you received.
E. The process of stage D is not instantaneous. Why? You are not the only person to have called that minute, or called in the last hour, in the last 24 hours, that’s why. Patience is your friend. If you get very bored, you can always start wishing you’d never been ripped-off and start pushing your vehicle instead.
F. At some point a rescue bloke will appear. If you are in Italy, he’ll probably be Italian and he’ll likely to be French if you are in France. You can guess what he’ll likely be if you are in Spain, the UK or the Slovak Republic.
G. This fellow will likely be driving a car carrying vehicle. Why? That is because there are many more cars on the roads of Europe than there are motorbikes.
H. If the fellow can repair your breakdown then and there, great. Off you go.
I. If he can’t, they will probably take your vehicle to the nearest fully authorised dealership for your make of vehicle. Why do the ‘idiots’ probably not take you to the general garage you can see two hundred yards away? That is because a fully authorised dealership might well have the diagnostic tools / parts available to hand then and there.
J. Not every country has an authorised dealership on every corner of every village. This means your vehicle (and you) may need to be relayed some distance. This will take time. If you breakdown on a Saturday, most garages are shut on Sunday and many in Europe for at least half of Monday. This will further delay the process. If your breakdown also falls in some strange local holiday for the Feast of the Immaculate Virgin’s Sister-in-Law, that’s just tough luck. Comfort yourself that plenty of Europeans will moan if they breakdown in England on or about our unique August bank holiday.
K. Listen to what the RAC tell you. They will listen to sensible counter proposals BUT take care, if they enact your cunning plan, they are then under no automatic obligation to assist you further, should your oh-so-cunning plan fail.
L. If your vehicle cannot be repaired in a reasonable period, then (subject to tge terms of the cover) you will be offered alternative transport. This may well NOT be a motorcycle. Why? See G above. You can cry if you like or you can set about repairing your vehicle yourself or you can start pushing. The choices are yours.
M. You can now continue your holiday, as planned. What happens next might vary, depending on whether the vehicle is repaired, how they then propose to reconnect you to it and / or whether the vehicle is then repatriated back to your hometown. Again, listen to the options the RAC give you, refer to K above.
N. You may well have to pay hire costs, taxi fares etc etc then and there. Keep the receipts, to recover your expenses (subject to the terms as set out in the booklet) on your return.
It’ll be a huge comfort to know that I (and many thousands, maybe millions, of others) have called on help from assistance / recovery service companies at least three times in say 40 years of jaunting about in Europe. Each time it has worked really well, including the one time I did persuade them to listen to a sensible counter proposal, whereby I continued in the hire car around France, whilst my bike was recovered back to London for repair. This was better for me than having it repaired in France and then me having to backtrack back across France several days later to pick it up. I am not so precious about my motorbike, that I cannot stand not knowing where it is every second of every 24 hours.
