Well..... Still doesn't work.!
Fuel gauge showing full with a range indicated of 222 miles, put £25 + petrol in it, fuel gauge still shows full, just done 72 miles, fuel gauge still shows full and I now have a range of 236.
On board computer shows 51.3 mpg
Getting a bit daft now.
Any thoughts.?
I'd say its doing exactly what its meant to do - the last thing you should have done - as I tried to point out in my reply 2 june - is to fill it up - the bike appears to have some logic where it needs to see a couple of times - the full to empty values to fine tune the display
mines now a bit different - I have gone float-tastic with the dutch bods computer 2 thingy, which converts the signal to strip madness. But hadn't wired it to a good electrical connection and the bodge temporarily disconnected a few times and throws it in a tail spin - sorted now and as the level is dropping the display and range to empty are rapidly coming back in to sensible areas - not sure why but the kit doesn't give long enough wires or the relay he reccos linking direct to the battery switched via the accessory socket near the battery.
