Will a Slip-on from an 07 fit straight on to a TC please?
If so, will the Flappy Thing need messing with at all?
TIA,
BB
TIA,
BB
Personally I'd recommend ditching the Flappy Thing as it's a PITA!
I got Racefit (end of the road) to run me up a replacement section of pipe
No - just remove exhaust flap and tape up cables.
Thanks for that....
Ah right, I thought I’d read something about having to install an Electronic Gadget somewhere.
Rarely ever simple is it? ��
Oh….now I’m not confused at all….That's on the Water Cooled versions.
If you remove the flap valve you may as well remove the operating motor assembly as well.
Either way it will throw up a fault code on the ecu.( the fault code is thrown up if you just disconnect the mechanical operating cables ).
I have no idea as to weather this code affects any other parameters in the ecu , it does not appear to but after a while I fitted the little eliminator box which stops the fault code being reported.
......The best place for the flap valve along with the operating servo motor is over the hedge.
I understand that the flap valve is designed to shut and quieten the exhaust at the rpm / speed that the legislation calls for a specific dB reading.
So....As I've yet to jump into this "Operation", what's everyone's thoughts on De-cat Headers with Std Can, as opposed to Aftermarket Can on Standard Headers please?
May as well explore all angles before committing!
