cwells
Hello,
I have a 1995 1100GS and I have had issues with it not catching on startup and especially when it's warm. On startup, it will take several attempts to get it going and have to rev it more than I think I should have to but can eventually get it if it's the first time I try each day. It's even worse after riding for a while and am in constant fear that it will stall on me because if it does I will be stuck there. I had it maintenance last winter but it ended up with me losing my confidence in the mechanics as after 2 times bringing it in all they did was replace my throttle body and not solve the issue. I am admittedly new to this and have only had it for a year. When it runs it's amazing but starting it up is having me consider selling it. I will have more money in the summer to get it maintained again but would like to have a better idea of what's wrong or even better, I learn what's wrong and do it myself if possible. I replaced the spark plugs today and it still hasn't solved it. The problem is solved (barbarically) if I use started fluid but I only have done that once when it was stuck in a bad place. Any recommendations or questions are appreciated. Thanks!
Chase
Chase
