Pin 30?? What is this please? And Dr Farkoff, I’ve no idea what this is… I’m not great on electrics….
As Mista has shown above
Terminals have numbers
IN the auto industry there is a generally adopted practice that terminals / pins are numbered
30 is usually the "hot" supply 87 is the "load" Spotlamps or Horn or in this case the starter solenoid feed wire
85 and 86 are the Solenoid activating circuit
Usually one is a ground and the other an Ignition live (or run off sidelamps as I would fit for additional light activation)
all the relay does is "bridge" the heavier load circuit between the battery and the starter solenoid or lights or Horn, so that the lightweight electronics do not fry
