Hazard warning lights
Doc
Let's Av It
Slawit
For some reason my hazard warning lights came on when I switched the bike off today.
Struggled to get them to go off. I hadn't mistakenly switched them on.
Anyone any ideas.
Cheers Doc
Its the bike fucked time to replace warning system ..
Better get a new bike, the cost to repair will be horrendous ;)
That was so helpful!
I thought you were a much nicer guy!
Sent from my SM-A125F using Tapatalk
Ok, but if I ever move my bike with the ignition off , the hazard lights have a fit !
Maybe I moved the steering then as out on bike now and hasn't done it again.
Just be glad you don’t have the siren…..
Can’t see a few flashing lights deterring a thief !!
The way I see it … it’s warning you that you don’t have the fob in your pocket….
But….. if you have not changed the security code, and you know how to enter it you can be away on the bike without fob or keys..
I must change mine….. still “factory”
It did it again yesterday. :nenau
Then dash said my key fob battery was low. Wonder if it is thet ? I will change the battery and see if that cures it.
