New bikes in showrooms seem to have valve fitted, or at least the one I saw locally recently did.
New one bought start of June and it was fitted, but...
The rubber valve disappeared. Awaiting info on replacement
No NBU 30 Stuburags been used on that, you can’t miss it, it’s white and very sticky! Here’s mine for comparison, just before installation
Will all new bikes in summer 2022 have a vent fitted at the factory?
Do you know above how many kms they replace the shafts?
The outer face isn't part of the sealing surface, so that coverage might be a little overkill, but agreed, it's nigh on impossible to apply the Starubags without it being visible when you gently peel back the lip.
Agreed, it was overkill, but then, I had plenty to spare and another 2 kilo to collect in France next week
Unfortunately, my 2016 GSA, at less than 5 k miles, when I bought it and otherwise looking very clean, (privately on here) was one of those with the driveshaft firmly rusted to the rear drive and I had to take the rear diff off, complete with drive shaft, before I finally managed to split them, hence some reasoning for the overkill.
I am sure i read anything in manufacture from Oct '21 will have the vent fitted.
My June '22 does
Thanks again for the provisioning of the white uber-goop for the forum John!
Which makes me wonder why Bahnstormer Alton service told me that there should be no rubber bung in the hole?
My bike is Dec21 and came with a hole drilled but no bung…
Reply from dealer:
I have checked with the technician and it does look like the rubber bung has come out of the hole.
We do have them in stock so you are more than welcome to call in at some point and we will get one of our technicians to re fit it for you?
Mine definitely had a rubber plug fitted when I bought it, so goodness only knows where it went, looked a bit like a squared off ducks bill
I do wonder where dealers get their info from???
I suppose I have to go back to Bahnstormer again.
Which dealer where you speaking to?
Does anyone know the real details of this mod? seems like an awful lot of speculation and misinformation (normal fir a motorcycle forum).
Is it simply a drain hole with a bung? or something more sophisticated. I can't believe the 'rubber valve' theory, how would that work?
